I think it just needs a cap kit, but...
Cachorrito2
New York
So, when I turn on my Ms Pac Man, the right side of the screen is bending its lines upwards, then sometimes that goes away, and other times the screen bump and shakes occasionally. Does this sound like a problem that a cap kit would fix?
Thanks!
i think what there saying is...
if you are there, you may as well do it..
most likely the vertical folder over (looks like horizontal becuase monitor is 90*) is caused by a dry cap..
heh, when you cap a G07, the old flyback goes kaboom for real. that's why they say it. :)
Ok, I'll take your word for it and replace the whole thing. Thank you for your counsel. Nice to be back on the forums.
I specified replacing it if the monitor is a G07. Before buying any parts you need to verify the monitor type. G07 and K7000 monitors have notoriously bad flybacks.
I just fixed the trapezoid issue on my 4600 with the cap at c614 and cleaned up the solder joints on the pincushion transformer t603.
-Ken
