crassvw
I scored a Space Invaders cabaret, anyone need parts?
Picked up a Space Invaders cabaret today, got a good deal on it, and I was looking for a winter project. The bottom of the cab had some water damage to it, but other than missing the coin door, everything looked pretty clean. When I turn it on, the monitor turns on, and the marquee lights up, but no image or sounds. On the backside of the last PCB, it looks like it is flaking off on the solder side, and I noticed the small PCB (from the harness, marked "D") to the left of the coin door, appears to be cracked straight across where you would plug it into the harness. So I am not sure if that is why it is not working.
So if any one is in need of any of the following parts, please pm me. I am open to offers and would like to see them put to a good use.
Complete wiring harness
Black plastic trim (under the glass to the monitor that held the colored plastic down)
Joy stick and buttons
PCB holder
PCB (not working, did not power on, damage noted above) and all cables
Monitor and wiring chasis
Metal coin box
........pretty much anything inside of it
PCB holder
Metal coin box
