I need to swap chassis
INOVERMYHEAD
Ohio
My chassis is f---ed so iam swaping it out, it there any reason a Wells Gardner 19 Inch K7200 Standard Resolution Chassis would NOT be an ok replacement for my WG19k7901 19" standard res. Iam pretty sure it would be fine, but just want to double check with you guys.
If you're swapping entire monitors....that's fine. If you're talking about putting the 7200 monitor board on the 7901 tube/yoke....that won't work. The 7200 and the 7901 are two very different beasts. To do this swap, you'd also have to swap the yokes....and you need to make sure the tube neck pins are the same.
Edward
