Gov
I need some help with some monitor adjustments please!
I picked up a Dynamo cab today off of CL and it has a 39 in 1 board in it. The owner said it seemed to work fine other than the picture was too big for the screen. It was a good deal so I picked it up anyways as I have been wanting to build a multicab and I figured using a Dynamo cab would keep me from at least being burned alive here
Anyways, I have been working on the adjustments and I have the color pretty good now and was able to adjust some of the vertical size and such, but the picture is still stretched vertically way too much (see pics). I am going to assume this is a Zenith monitor of some kind as can be seen in the pics. From looking at the board diagram the Horizontal Size control is way over on the other side of the board from the other controls and no reachable while the monitor is plugged in and charged. There is however a hole in the bottom of the frame that goes through to the PCB. I can't quite get my head in there to see if there is an adjuster of some kind but it looks like it is in about the correct place for the Horizontal Size adjuster.
Is this where you adjust this? I am assuming this is the adjustment I need as all of the other ones didn't do what I needed regarding the picture.
Any help would be appreciated.
Thanks.
Thanks.
