andykmv
I need info about QBert - PCB header and thru hole eyelet dimensions etc
I have a qbert machine (not mine) needing repair with a broken header plug (3 pins broken off) and the pcb burnt/damaged thru holes, and I need to know
a) the pin size, type and pitch of the pin headers used
b) the inside diameter size of the PCB plated thru hole (for the purposes of eyelet repair) and eyelet diameter and pcb thichness (the pcb substrate thickness only, not including copper) for the cabling headers on:
- the sound pcb
- the filter pcb
so that i can plan to take the appropriate parts and eyelets/tools with me to effect the repairs needed.
- the sound pcb
- the filter pcb
