JBuck8
i bought a golden tee 04 cab with all the componets but nothing was plugged in. Turns out the chassis is not the right one for the tube. The guy i got it from is looking into getting the right chassis but until then he is letting me use a 27" nanao ms9-29su from a time crisis cab. Now my problem is there is only one connector coming from the chassis. It has 9 pins. I think the original well gardner k7500 setup has a cable that goes to the pcb and one that goes to the power supply. Can i use this monitor in my golden tee cab and if so how do i rewire connectors to make the hook together? I can take pics and post them if that will be any help.
Thanks for your time
Jeff
Jeff
