I need Double Dragon front glass info, if you would be so kind.
Eternaliquid
Colorado Springs, Colorado
This is for a dedicated cab.
What I would like to learn:
-Is it glass or plexi
-Dimensions of said glass
-Thickness of said glass.
I'll go second!
Tempered glass.
(I think)
I don't have mine anymore.
Pull out the bottom drawer and look inside and take some pics of what you see.
I wonder if yours is made from other games like mine was...
These were the dimensions I was given, I'm needing one myself.
24 3/4 " H X 22 15/16" W - 1/8" thick
Keep in mind some of these cabs have an attachment at the top to hold in the glass. This will change the dimensions. I don't have a pic handy right now but others/Google may. I have it, along with glass. I can measure later.
ALL dedicated cabs have the top bezel retainer.
I haven't looked closer at how the glass sits in the cab. I'm assuming the glass slides up into the slot at the top. I'll have look for a bezel retainer, perhaps up inside behind the marquee.
Yes, it slides up into the slot and then you set it down. That's what the hand hole at the bottom is for.
Did you look behind the drawer?
