I need a wg6100 tube, what are my options?
Drop-in fit for @shilmover's XY kit, which IIRC has the same yoke pinout as a 6100.
Shilmover kit just has pins so it would fit any neck but he made a b&k cr-23 style neck board for it. Are you saying that television has the same neck style as a cr-23 or for the kind that would fit a 6100 100° neck?
Post some pics of the necks. Are any a CR20?
I did a little while back in the tube swap thread, I think? They are all SUPER weird. Not a standard neck of any sort.
Post 151 is where I had some pics.
The tubes in 151 and 152 look like CR-20s to me.
There is also this thread about making an adapter.
And then this thread:
Ya, those are CR20 necks. @dezbaz makes a conversion neck board for those. The only thing that I've found that if they have dual focus you need to add resistors to the focus line inside the HV cage. I'm still working on the exact number of 33M ohm resistors, as I'm currently having issues (unrelated) with the deflection board. Once I get it back and running I'll figure this out
So, in cleaning up the chassis, I noticed the little add on board, is this the lv2000 mod? This one looks like it was don at the factory with an atari add on board
No. That's a different one. That is an Atari board.
Does it do the same thing as the lv2000 mod? Im new to these kind of monitors, havent played around much with vectors.
No that's an input protection board from Atari. Depending upon who you talk to they are, or are not, useful.
The LV2000 boards replace the the low voltage circuitry on the deflection board.
Bakerhill is right, that's the IPC board.
If you want to do yourself a favor, remove it. They're pieces of junk, and cause more problems than they fix. You're actually MORE likely to have issues with it than without it, as those legs really like to loosen up where they are soldered to the board, and your deflection system stands a good chance of frying when that happens. I've seen it on many deflection boards. I always remove them on all 6100 boardsets that I refurb.
To remove it, just desolder all of the legs, pull it off, and then replace the following four resistors:
- R600 and R700 (1.2k 1/4W)
- R606 (4.7k 1/2W)
- R706 (2.2k, 1/2W)
The result will be many fewer points of possible failure, and a more reliable board.
- R606 (4.7k 1/2W)
- R706 (2.2k, 1/2W)
Thanks Andrew! I will remove it.
You guys do know you can pull that white plastic part off the end of those 100 degree tubes and use the put the plastic from a 6100 on the end to make it fit CR-24 style plugs right? So long as you have the plastic peace that fit on the 6100 of the tube you are replacing still.
If it's a CR-23 tube, that'll be fine. If it's a CR-20, that won't work. Not the same pinout, has dual focus pins, etc.
