learpilot2
I bought a star wars that had a non-working WG monitor in it. I did a cap kit, and installed a LV2000 mod. I changed all the frame transistors also.
I turned it on, and I heard beeping and deflection chatter for 5 seconds, heard a big bang, and smelled smoke. I looked around the back, and the entire yoke cracked in half and was dangaling by the neck board wires. The glass tube (neck) broke in half and separated from the picture tube.
What in the heck did I do? I have recapped many monitors with no problems. What would cause such an explosion??
Next question. Is it safe? The neck is swinging by wires, the picture tube is open. Is it discharged? If not, how do I discharge it?
What is the fix? Can you buy new tubes? Not sure I want to hook a new tube up to a unknown problem???
Thanks for the help.
Rick
Rick
