Dokert
I just recapped my XXX monitor, now I have no Y color
I am seeing a lot of these posts lately, and they read like this... I just recapped my XXX monitor and now all I have is Y color or Z color is missing.
Please keep in mind that if you have just recapped a monitor, it WILL require adjustment. Depending on the make, model, and how badly it needed to be capped will determine the amount adjustment needed.
Common after cap kit adjustments include any of the following:
1. B+ (especially on G07's and Sanyo's such as the 20EZV)
2. Brightness on the flyback and or the chassis
3. Horizontal Width Coil
4. Horizontal Freq or Horizontal Hold (Depending on make and model)
5. R, G, B bias and cut off's on the neck board and or chassis.
6. Black Level Pot (especially on a WG4600)
just to name a few.
If after all of your adjustments are done, you still have just one color and or a color is missing try rejuving the tube. Hooking the tube up to a rejuver will tell you in most cases if the problem is in your tube (Color guns) or a bad color transistor.
just to name a few.
