I give up, finish my Mr/Mrs Pac pin project
Oh, I've been there with some other projects in the past. At least yours is something that people are interested in. A rusted out old half-rebuilt jeep? Bit harder to find a buyer.
-Hans
Could be several things: ground issue, EOS switches, board, or a fuse.
My advice: You put this much time into it so just deal with it and finish it. You are going to kick yourself in the ass for letting it go after putting so much work into it. Then you are going to buy another one and have the same issues!
I second this. It will be so rewarding for you to finish what you started. I'd love to have the machine, but I'd rather you not give up on your restoration.
I cant work on this anymore and you cant make me, Splattergatz. Dont you understand, my sanity is at risk here!! LOL
hehehe
yes, it often seems like im going to lose my cookies trying to track down problem childs lurking in wiring harness or transistors showing ok but under load they fail, etc.
just saw a pin like yours for sale here for 895. we are generally about 300 cheaper than either coasts sorta too. so 1200 hundred ish depending on flaws could make it worth it to really go the extra mile and let(these are not the droids you are looking for)me use my brain to push you over the threshold into problem solving your fine project that needs you so bad to fix it ! when you do fix the problem, just think what an expert you will become and how much more you can charge per hour the next pinball joe who's broken machine you can fix with your eyes closed !
