i feel like an idiot. How to turn on a 60 in 1?
milkit
Mesquite, Texas
I got my 60 in 1 from nixs and I have it plugged into a 4 pin molex (pc power supply) as it says.
Now comes the "i'm an idiot" part.. How the heck do I turn it on?
The engrish directions made me think I held down service or test for a few seconds to power on, but that doesnt seem to work. Soo... how do I get it turn on?
Thanks!
Put a jumper between 14 and 15 to turn your ATX on
This was stated above but just for color-coded reference if you are using an ATX just short the green wire (should be only one) to a black wire, then flip the switch on your PS.
Thanks!
There is no switch on the board. Once you get power to it, it comes on. See directions above on how to get power to the board if you are using an ATX power supply.
ken
awesome thanks, had to clue I had to do that.
i striped the ends of one ground and the down button and touched together to test and i get nothing as far as menu control. I am using vga so not using the jamma monitor part of the harness. do i need to wire a/all the ground on jamma harness to the power supply too?
i really do feel stupid, just never messed with this kind of stuff before
Guess you got it on, yes you have to jumper the PowerOn on an ATX power supply.
I've tested before with nothing connected and just jumping from ground to the correct pin.
Think you need to coin up first before a direction will work. Or you could try putting it in test mode (there is a switch on the board, or a pin on the jamma connector when its powered up) that will let you go through the setup menu.
oh I figured the multi would let you look through the games and possibly even select a game before putting coins in. ill try that.
