I don't know about you, but I'm playing Quantum tonight.
bungy
New Jersey
Sort of - at least I don't have to use MAME anymore. I got one of the final pieces yesterday and I hooked everything up with a reconfigured spare Space Duel harness and a custom control panel harness. I just need the cabinet/art now!
I'll be checking into the Scotch thread a little later :)
attachment.php
attachment.php
attachment.php
attachment.php
cute
I'm not being facetious, I want specs.
Is it 100°? Looks like a CR23, not 24? Tube number? Manufacturer/model #? Yoke used? It might not be correct per se, but it's showing picture pretty well for a test setup at least.
Did you use the yoke on the TV?
But seriously, the TV frame and multimeter are just there to support the tube. The tube/yoke is a regular med-res Rauland that I got with another game. The tube has some internal damage that is irreparable, but it works for now.
Understood. Thought you made up a frankenvector there for a minute.
Is it 110°? Looks like a CR23, not 24? Tube number? Manufacturer/model #? Yoke used? It might not be correct per se, but it's showing picture pretty well for a test setup at least.
Sorry to get your hopes up, but that is not the tube that came with the TV. Whatever tube did come out of that TV I either used in std-res raster or threw out because it wouldn't converge. I have never found a compatible yoke in a TV.
I can play it too ;) And +1 on all I need it the side art.
I looks good on the floor like that, very easy to hook a scope and analyzer up to troublshoot if something goes wrong. :)
Wouldn't a CR23, std res tube actually match what came in Quantum? I thought the Amp tubes were CR23/90deg while the WG6100 tubes are CR24/100deg
I don't know, I never found a clear answer on what the stock setup was in Quantum. I heard that early ones had std-res Amps, but I don't know if all of them were.
If I can get a med-res tube, I'm going to put the Amp in my Star Wars and put its 6100 in the Quantum. Otherwise I will probably go with a std res Amp setup in the Quantum. The med-res tube I have has a damaged shadow mask.
