chriz74
- Joined
- May 6, 2024
- Messages
- 65
- Reaction score
- 23
Hello, yes. The top of the crt socket has the numbers engraved on so I checked those and for the receptacle I considered the number 1 to be the one shown in the diagram that I think indicates the female part ?What I mean when I say "mirrored" is the diagram you have shows the top view of the socket, but when you are soldering I'm sure you will be looking at the bottom of the socket, so just make sure to account for that.
What calibration do you suggest? I picked one up recently and bought a cap kit for it but haven't tried it at all yet.The B&K 467's are 30-40+ years old. I've rebuilt probably around 15-20 and I have only found 1 that I didn't find anything wrong with it. Cold solder joints, leaking caps, out of spec resistors, failed diodes and transistors are all common on these. Not to mention all of the other surprises you find from people trying to repair them or damage from wear and tear.
With that said, I don't recommend using these as a trustworthy testing/restoring tool until they have been fully refurbished and recalibrated.
Heater VoltageWhat calibration do you suggest? I picked one up recently and bought a cap kit for it but haven't tried it at all yet.
No it was included in the item I boughtDid you pull that socket from a neckboard?
I did my first ones like that, but now I just leave the socket connected to the PCB and cut applicable traces. More durable and less likely to lose.
