I can convert a Wacko PCB to a Domino Man PCB, right?
blkdog7
Massachusetts
I know that according to the MCR FAQ, it says that Wacko and Domino Man share the same board stack.
However, it says the following:
The following can be converted from one to the other with EPROM swaps:
a) TRON, Timber, Kickman, Satan's Hollow, Two Tigers, Wacko
b) Spy Hunter, Tapper, Discs of TRON
It doesn't list Domino Man as one of the games that can be converted. Is this true?
If I can convert it, which EPROMs do I need to swap? ALL OF THEM?
MCR FAQ:
http://www.crazykong.com/tech/MCRfaq.txt
I wouldn't trust the faq. I know for a fact that it has a few errors in it.
IE timber and tapper - same pcbset. One is listed as mcr2 and one as mcr3 cpu. Kick/kickman while listed as an mcr2 pcbset and also as interchangeable with tron/satan's hollow etc, uses 4kb eproms vs 8kb in tron, sat. hol, etc.
I don't have a wacko here to look at, but looking at the manual, it appears to be the same pcbset as a domino man/Sat. Hol/Tron.
And yes, you have to replace all of the eproms on all 3 pcbs.
Ok, cool. THANKS!
I converted the Wacko to Domino Man this weekend. Went smooth. Domino Man seems to be working perfect again (KNOCKS ON WOOD!)
