I-Cade Dip Switch
wmacmonagle
Donor 2012
Rosamond, California
Im not sure if there is already thread posted regarding to this but.. If so.. Please post thread here so I could get answer promptly.
I had figure and installed I-Cade 60 in 1 multi game..
Problem here is...
I tried to set up dip switch to enable
free play
player 1 Cocktail style
player 2 Cocktail style
I checked manual and noticing there is dip switch for it.
Everytime I put dip 4 on and it takes me to test mode. I couldnt get game to play what I wanted.
I inspected and found out there were a step 1 of dip switch
Now how can I get point where i could set up freeplay and player 1/2 cocktail style so monitor will flip everytime each player's turn.
If anyone acknowledge how to do it. PLEASE HELP! thanks..
There is only 1 of 1-8 dip switch on board I can find.
The other dip switches are software based.You get to them through test mode.I believe you need to have the cabinet test switch and service switch wired to navigate the screens.You will find the cocktail and upright dipswitch in there.
If you read in the manual under II system setup,there is a paragraph there describing how to navigate the menus.I hope this helps.
1) Turn off the game and turn on dip switch #4 on the PCB, then turn it back on.
2) Wait for it to boot up to the color-grid screen.
3) Push S2 (the 2nd action button) twice. This will put you on the System Setup screen.
4) Notice at the top of the screen, you will see a bunch of OFF's in two rows. To the left of each row will be a 1 (Dip Sw1) and a 2 (Dip Sw2). Above each OFF will be numbers 1-8 (for each switch). The top left OFF will be surrounded by a red box.
5) Move the joystick down once. The red box will now be on Row 2 Position 1.
6) Move the joystick right twice. The red box will now be on Row 2 Position 3.
7) Push the S1 (first action) button once. The red box will now say ON.
8) Do the same thing for Row 2 Position 4.
9) Push Player 1 Start. It will say "Setup" quickly followed by 'Setup OK" on the screen. This means you have saved your changes.
10) If you have other changes to make to any of the individual game settings, press S2 to advance to each screen, use the joystick and S1 to turn ON or OFF the switches you want (using the settings listed farther into your manual), and push Player 1 Start to save after you finish each page.
11) Shut off the game and turn Dip Switch #4 on the PCB off again. After a few seconds, turn it back on...
got things figured out.. im so idiot cuz my cocktail has no button. I was not able to hit next so i had to use wire and attach to button 2/3 and hit ground and it respond.. so i just got every setting i needed for now until i hack 3 buttons into it..
thanks klov!
That's pretty much what I did on my 48-in-1, since the cab it's in (Gaplus) only has 1 button. I'm not hacking another button in it, unless I get a 2nd control panel, since the machine is all original (48-in-1 is hooked up via a JAMMA cabinet adapter)
