WindDrake
Hey all.
Did some searching, and haven't been able to come up with an answer on this one. Me and a buddy at work have been hashing this one out for a bit, and I feel like we're missing something.
Now, I'll preface this by saying I've never had the pleasure of diving into the guts of a Vector display. Only raster monitors.
On a Monochrome Vector, the monitor's deflection is directly driven by the deflection board, along with the Z-Axis (Intensity), right?
On a raster, you've got the Horizontal and Vertical Scan Oscillators hooked up in line with everything else.
Is there any technical reason you couldn't use a B&W "Raster" display, say out of a TV or some such, and disconnect the Horizontal and Vertical oscillators, then hook the H/V Amplifier Inputs to the appropriate deflection controls on the deflection board?
As a side note, if you drove all of the color guns in a Color Raster from the same signal line (Creating White), wouldn't this be similar in appearance? (Similar, not the same! I know the Shadow Mask gets in the way.)
Thanks for fielding my questions.
