Hypersports sound and high score issues
Boo32
Richmond, Virginia
Hypersports PCb plays well with two errors
1. Anytime there should be speech - get set, foul, qualify - it says on your mark instead
2. The high scores are readable for swimming but for the other events there are smiling heads in the place of the high score numbers.
Trying to see if this is a chip replacement issue before I send the board out to be repaired.
Chris
1. Beyond the normal reseat the socketed chips in the audio section you'll have to delve into circuit repair.
IC F12 controls the flow of data between the game and the audio section.
IC C14 controls the flow of data between the sound CPU and the IC that generates the speech.
IC A13 controls the speech while A9 and A7 are the ROMs that hold the data for it.
2. Flip the dip switch to reset the high scores and reboot game. If this fixes it then replace the battery on the board.
Batteries Plus can spot weld leads onto the coin battery so you can solder it in easily. I've done this for other T&F and HS boards.
RJ
