Any suggestions on a high voltage probe for discharging monitors? Are some better then others? Just not looking for the screw driver with an alligator clip type.Thanks.
This might sound like a dumb question, but how do you tell what impedance a multimeter is rated at? Are you just referring to the Ohms rating? I'm thinking about getting a better one:Also, unless you get one with a built-in meter, you will need a Multi-meter with 10M Ohm Impedance to use the probe and get accurate readings.
http://us.fluke.com/usen/Products/F...FlukeUnitedStates&Category=HMA(FlukeProducts)
