troxel Well-known member Donor 7 years: 2015-2021 VAPS Joined Mar 19, 2006 Messages 2,084 Reaction score 104 Location Lincoln, Nebraska Mar 17, 2010 #1 I just got a used unit of eBay, and was wondering what is the best way to test it? I really don't want to test it with a fully charged monitor. Thanks, Theron
bjk7382 New member VAPS Joined Mar 1, 2005 Messages 832 Reaction score 2 Location Dorr, Michigan Mar 17, 2010 #2 You can just test a monitor while it is on. See what the kv is and then look in the manual and see the ideal spec, probe tested.
KSKID Active member Donor 2017, 2020 Joined May 21, 2003 Messages 1,456 Reaction score 16 Location Kansas Mar 17, 2010 #3 What kind did you get ?
OP OP troxel Well-known member Donor 7 years: 2015-2021 VAPS Joined Mar 19, 2006 Messages 2,084 Reaction score 104 Location Lincoln, Nebraska Mar 17, 2010 #4 It's an older Simpson model #00432. Don't know if I trust it or not. Theron
bjk7382 New member VAPS Joined Mar 1, 2005 Messages 832 Reaction score 2 Location Dorr, Michigan Mar 17, 2010 #5 As long as the plastic / insulator isn't cracked or smashed there is no way it should work any different than it was originally intended.
splattergatz Well-known member Joined Jun 20, 2008 Messages 5,756 Reaction score 52 Location Belton, Missouri Mar 17, 2010 #6 if you are nervous about it, get a used inner tube from a tire and wrap it around the handle. the extra rubber outta do it and if you make it longer, you can hide some of the wire behind it too.
