Hurricane pinball outhole coil random fire
pintech
Amory, Mississippi
Hello,
My Williams Hurricane pinball suddenly started random firing the outhole coil. It does it during play and attrack mode. I have been checking and nothing so far.
Any help and ideas would be greatly appreciated.
Scott
Switch is occasionally sticking closed, or machine thinks it is. Then I'd be thinking switch matrix issue. On the same row or column you have something shorting to switch lugs or wiring.
Look at the switch matrix in your manual to understand the row and column that switch is on, and then what switches to check next.
Also you could go into switch test, bang on the playfield, and see if a switch closes - then you know which ones needs adjusting. LTG :)
