Hs-5 dynamo cabinet
deuce2
Ogden, Utah
I have a HS-5 cabinet and recently bought a horizontal 138 in 1 pcb board. I was wondering how to rotate it from verticle to horizontal.
Start opening it up and you'll see that the monitor hangs from these wood brackets and 4 bolts and wing knuts that hold them down.
Remove the wing knuts and rotate the monitor.
you probably should look at the remote board and the video cables before you rotate. Make sure there is room to move (or disconnect the monitor before you rotate)
Make sure all 6 screws(well, atleast 4) are securing the monitor to the wood brackets. I have seen some ops trust gravity with 2 screws before.
When you remove the glass, wood bezel and paper bezel, you will see the wing nuts holding the wood brackets. The wood pieces make it square so it all fit when you rotate it.
