If you have been following my Omega Race repair status thread, you'll see that for some reason, the 9-pin connector that goes to the linear PS board from the filter assy is missing the ground wire at the #1 pin location for some reason. I would like to add this in, but need to know where I would put the end heading towards the filter assy? Can I just screw it into the frame of the filter assy? I know that there are little tabs on the assy that the different wires all connect to, but I believe that they are all filled and do not see one specifically for a ground wire.
Thanks!
Thanks!
