How to save setting on 60-1
stingray2309
Romulus, Michigan
Please forgive me if this was asked before I tried searching this subject using my phone / Klov app and found nothing.
Yesterday I finished a 60-1 for a friend. It was really loud so I went into the setting and turned down the volume. Two problems once I made all my settings I was unable to exit out of that screen so I had to turn the game off. When I turned it on the game was just as loud as before no changes saved. So how do I change the settings and save them? Also how do I exit the set up screen and get back to the game select screen ?
This is the newer 60-1 i don't know off hand where or who he got it from but I can find out if that's important.
Thanks for any and all help
Should be press and hold Player One button. It will then say saving on the screen.
, Bill
You don't have to hold it. Just push Player 1 Start. It will say "Setup OK" when it has saved. You can save after each screen or after doing all of them. You have to save by the Volume Adjust screen, as it won't work on the last Input Test screen. And if you don't have the Service button hooked up (or S3 depending on how you got into the Test menu), you won't be able to back up to the volume screen to save.
Once the settings are saved, the only way out is to turn it off and then turn it back on without holding the Test button or with Dip Sw 4 off...
