I still haven't seen anything from Cosmodog / Andrew Pines on when this will become available.Did you or anyone ever get the new "Revenant Bowl-o-Rama" one replacement board that runs on Rasberry Pi ? If so, I have 2 of these games and need them
it was never made.Did you or anyone ever get the new "Revenant Bowl-o-Rama" one replacement board that runs on Rasberry Pi ? If so, I have 2 of these games and need them
Yeah, I've verified that other boards with similar chipsets works too.Brilliant work, I got mine running, and fantastic game it is!
Luckily the seller had a replacement board he couldn't get to work, and also the original
Couldn't believe how simple it was.
Unfortunately that board has died too, plus another I sourced, about 3-5 hours each.
Im now thinking the psi is at fault.
But struggling to find a board, has anyone tested other boards?
will a similar chipset work that is not ECS branded board?
It would probably depend on what cabinet you had (dedicated or conversion), and what the condition of it is.so with this in mind. what is a DOA cabinet worth?
Nothing! Ship it to me and I will dispose of it for you.so with this in mind. what is a DOA cabinet worth?
dedicated pedestal. pristine cosmetically other than missing the ash trays.It would probably depend on what cabinet you had (dedicated or conversion), and what the condition of it is.
whats your hard drive solution? many old PC's that share the +12 with the drive and the audio amp will do this. Try a ground loop isolator on the audio output.Any one had static on speakers?
Mines making loads of squeals and pops when it's loading, as the dos lines flash up on boot the noises seem to happen per the line.
Does that mean my amp has gone?
I've tried alternative wire to amp and also new psi and mb
my money is on the thumb drive.Alright internet folks... I have my game up and running BUT the bowl rolls in super slow motion during the attract mode - anyone else see this? I have a ATI 9600XT and have tried 2 different motherboards.. I have tried a lot of other combinations of ATI/NVidia cards on a PCI-E motherboard and just can't get it to work. Thoughts anyone? Anyone add NVidia drivers to this Linux version?
ANY and all direction and help would be appreciated - OR maybe my OS is jacked - I'm using the USB. I tried to image it to an SSD - but something about mount points being out of wack - and let's be honest - Linux is NOT my strongest OS - Give me ANY Windows/DOS version... but me and Linux don't understand each other...![]()
Thanks ahead of time!!
That would be AWESOME if I could find it. I wasn't able to locate the files anywhere.. Maybe my Google foo is on holiday still....Isn't the virgin image online somewhere? Use that and write it to a USB SSD
MAY have found one actually, giving it a try!!That would be AWESOME if I could find it. I wasn't able to locate the files anywhere.. Maybe my Google foo is on holiday still....
Cheers but mine is on usb thumbdrivewhats your hard drive solution? many old PC's that share the +12 with the drive and the audio amp will do this. Try a ground loop isolator on the audio output.
