How to repair wire harness?
jumpman
Donor 2012
Iowa City, Iowa
I have a mario bros wire harness, the coin & lamp harness plug is cut off so I have a brown, red, orange, and yellow wire with no connector.
Where do I find a replacement connector? (the connector is still attached on the coin mech, so I need to find its mate.
Do I need to buy a special tool to attach the connector?
Or is there someone I can send harness to for repair??
I have a couple more wires that have worked themselves loose from other connectors too...
Sorry for the dumb q's any advice offered would be great, thanks
Pic of the connector would help, in most cases you can find a mate, or just buy a new matching pair with pins, and just re-pin it (incase you can't just find the mate).
If you don't have extractors to remove the old pins, then it's easier to just re-pin the whole thing, and in most cases better. You will still need to buy a set of good crimpers.
1st pic is coin/lamp harness, I would need the male end.
2nd pic is audio harness (maybe I can cut off old pin and crimp on a new one?)
3rd pic is the game counter harness (seems like male pin broke off inside connector)
maybe my best option for the coin lamp harness is to find someone with the male end with wire leads already attached, I would need to extend the wires anyway, they were cut too short to reach...
advice appreciated.
