How to removed steering wheel from Daytona USA
SilverDuck
Minnesota
I need to remove the steering wheel from the shaft on a Daytona USA. Does anyone know how to get it off? Is it pressed onto the shaft?
I'm thinking that you have to remove the steering cap- prolly hex or tork bits, then under that there is a bolt that screws into the steering shaft. It could be hex or a regular bolt head. Then just wiggle or tap the wheel up and off. Watch for the key to fall out of the shaft key-way as you pull the wheel.
