How to remove Tron blacklight
squall280
Pennsylvania
started tearing my tron down and got to the balck light above the controls. i can;t figur eout how to get the bulb out. it doesn;t look like you simply turn it.
You may have to push "in" on one side then turn it IIRC
Unless you have some sort of half-assed fixture in there, this fixture is no different than the other three. Twist the fucker and pull it out.
It may have the original 'cardboard' stays in it. Many fixtures originally came with a couple small pieces of cardboard that kept the bulbs from vibrating loose. You have to pull them out before you can spin the bulb.
