How to remove CPO from original CPO?
MKplayer1start
Toronto, Ontario, Canada
So I have this MK4 with a Namco CPO over the original MK4 CPO. I don't know what kind of CPO it is because you cannot get an edge to peel it off. The only thing that works is rubbing it off with your fingers till they blister lol
Any suggestions? I'll go out and take a pic in a sec
i've had good luck with grabbing any little bit i can and then hitting it with my heat gun just heating it a little. A plastic scraper can come in handy also (or metal if your extremely careful).
This one is weird cause you can't even get any little edge at all. It just falls off. I'll give the heatgun a try maybe loosen it up.
I'll pickup some goo gone on the weekend too. I've never really had good results with goo gone in the past but worth a shit with this one.
if you don't have a heat gun a hair drier will work also, goo gone might also soften up that namco overlay or atleast make it a little more pliable.
I would keep going with the heat and use a plastic scraper. If you are trying to save what it under there stay away from goo gone, it might end up taking off what you are trying to save.
