How to remove buttons from Ms Pac Man
colonelsnow
Florida
I am having trouble figuring out how to remove the buttons from my Ms Pac control panel. I loosened the silver nut but can not make any progress in removing the buttons.
Is this an all original machine or a modern ms pac multi??
Either way once you remove the nut(either plastic or steel) it should pop right out.
if it does not, it could be pop etc has been spilled in there and it could require some more force to get the button out.
I got them off. It was the accumulation of 30 years of gunk and just took a bit more pushing force than I would have imagined to get out.
Anyone know of any magic solution one can soak ("solid state") buttons in that will remove alot of gunk from the plastic and not corrode the spring inside?
I know that buttons are cheap but so am I. :cool:
