how to properly measure yoke ohms
jbaker
Arizona
do i measure with the wires connected or unplug the two connector and measure without the wires connected to the board and what setting should i use on the meter im using on of those cheap red meters from harbor freit ? thanks for any help
slight mismach of verticle ohms
ok the tube is a wells gardner it says WGEC tube type 088xo407-001
the chassi says p738-f im not sure but in think its a u5000 but it does not have a switchable connector to change frequencies just a blank spot on the board where another set of connector pins would have gone.
so its stuck on 15k any way my question is i have a universal chassi i would like to try
its for monitors up to 29 inch the ohms on my wells gardner yoke show as v 6.0 h 2.5
the universal chassi says the ohms need to be V-9.0 H-1.2 or higher do you think i would see fireworks if i try this chassi on my wg monitor the yoke ohms im worried about is the diffrence in V ohms do you think there is a big diffrence between v6.0 ohms andv9.0 ohms
thanks guys for any help
ohms
why not call or email the seller of the chassis and let then know your specs and see what they say
i dont know who the seller is i bought a candy cab with a 27 inch monitor and the extra chassi came with it. it yatta universal chassi model 988 i cant seem to find anything on the web about it.
monitor
i bet zanen elect. would know
he enjoys helping people with questions like this
1-888-449-2636.
Don't feel alone I have one also and it took me some time to figure it out. There are two monitor jumpers to set and my horiz width and Pincushion POTs was brought back to function with one cap replacement north of them. Mine has a label in back indicating only 25 and 29" monitors..PS the horizontal width coil is not directly adjustable.IMG_20220316_144416.jpgand is attached.IMG_20220318_114503.jpg
