How to open touchtunes juke.
Toonces1
Tucson, Arizona
A friend called me over and showed me the TouchTunes juke he had picked up. No key so he drilled the lock. He said he heard stuff fall inside and can't get in. Any ideas how to open this thing up?
Thanks!
I know that Rowe's should not be drilled out. The latches are at rest and the key loads the spring to open. If this is the case, good luck in opening it without causing any damage.
Haven't worked on that model, all the ones I've worked on are spring patch style a latch near top and bottom of door. If any play in door may be able slip coat hanger with book on end try to catch latch pull up. Any openings in back cabinet you. Can look through to see latch?
Well, someone got antsy, and drilling the lock probably wasn't the right answer.
Good luck with this one.
