squall280 Active member VAPS Joined Mar 19, 2010 Messages 1,382 Reaction score 19 Location Pennsylvania Apr 12, 2011 #1 How to move 4 player Simpsons into a normal door way? any suggestions? do i have to unscrew the front control panal?
TheDrewster Well-known member Donor 2012 VAPS Joined Oct 5, 2008 Messages 7,668 Reaction score 314 Location Reno, Nevada Apr 12, 2011 #2 Yes, there are just a mere couple of bolts inside the control panel and you can unscrew and remove the whole assembly.
Broodwich Well-known member Donor 6 years: 2012-2013, 2015, 2020, 2023-2024 VAPS Joined Feb 20, 2011 Messages 9,846 Reaction score 420 Location Albany, New York Apr 12, 2011 #3 thedrewster0 said: Yes, there are just a mere couple of bolts inside the control panel and you can unscrew and remove the whole assembly. Click to expand... This is exactly what you should do hope there are some molex quick connectors there for you otherwise you should label all the wires so hooking them back up is easier. My Sega Spiderman only had 1 bolt holding the CP box to the cab.
TheBasement Well-known member VAPS Joined Feb 22, 2008 Messages 2,729 Reaction score 341 Location Warrenton, Missouri Apr 12, 2011 #4 Yep, first unhook the top control panel by reaching inside the coin door. lift it up, then you have access to unbolt the whole assembly. Had to move mine in that way.
