NEW How to modify GROVEY GAME DOMINUX 8 for metal or cocktail cabs
Kickman
Donor 4 years: 2013, 2015-2016, 2024
Benicia, California
Thought i would share this, wasn't exactly sure where to put it at. So i just went to general because its not a restoration, its a replacement new sort of reproduction for a wico leaf style l
Heres the link to the stick
http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=65&products_id=407
They offer the stick in short and tall versions 4-8 ways or 8 way smooth circular which I bought 2 of for a multi cocktail Galaxian style to have some verity and save space.
I bought the short versions which just were not short enough to have room under the glass, and mounted in the metal style panels... i had to deconvert with a ton of holes in them...
So i welded them up, and modified the shafts to be shorter and i thought i would share so there would be something to see on a Sunday night on klov, lol
I had some cheap knockoff sticks that were at the hight i wanted but i hate, in most cases micro switches.. most cases..
Heres the hight i needed and the hight of my dominux 8 sticks for comparison
So heres how I modified them...
I took a vernier caliper using the depth gauge and made comparison....
And found that the shorter stick was
Little over 1/2 inch .580....
So, you can probably do this if your careful with out having access to the tools i do and own, but this will give you an idea of maybe how to try it if you like
I disassembled the shafts and then chucked them up in a lathe, thats twice as old as i am, or the same age as Arcrival, love you dave!!! Miss you homie!!
Now this is really important for you to know... credence clear water revival must be playing loud when using a lathe....
I used split mill blade and a end cut blade
down the shaft till i removed the .580
And ran it down flat.... now a savy person could simply just cut it straight other ways also...
So heres comparison to before and after shaft cut down
Lots of lube!!!
Now that both were cut even
I filed them flat by hand, not sure i have a pic of that but once i did, i chucked back up in the lathe to center drill...
So i had to determine the size of the center to drill based on the thread pitch and size of the original and what I believe is Industry standard for all of these ball tops, and that is m6x1.0
I double checked that with a tap
Actually thats a thread restore tap but i didn't want to put my sharp tap in the brass
So knowing the size of a stud i would have to reinsert with those threads M6x1.0 i cross reference using google and found i think was a #5 drill
http://www.gearhob.com/eng/design/drill_eng.htm
A number 5 is .2055. The closest fractional drove it slightly smaller than that was a 13/16 at .2031 i think is what i used
And drilled out the centers
Once i had them drilled i used a M6 x 1.0 tap and tapped the holes...
Once i tapped both holes, insert a dirty joke here, I checked to make sure that a M6x1.0 would fit and it fit real nice..
I kinda had to figure out how much stud should pop out of the shat so i did a little mock up
If you notice I installed the die on the stud before i cut it off, and the reason for that is to repair the threads after they are cut off with a cut off wheel
I used the allen head to install, with red loctite, into the shaft, installed the die and cut it off..
My clock is rad i now, and it should look like this
Then i installed the ball to be sure it was all good
Then i reassembled the stick
Heres a comparison to the the knock off
And i did 2 of them since its a cocktail cab
Hopefully that was at least enough entertainment to make it threw a dump.... lol [emoji23]
Its been alittle slow on klov and ive been tring to put out something to read every now and again, if not at least the klov grammar police to have something to do right, bahahaha
Happy for 4th of july everyone!!!
