Oven, cookie sheet, roughly 10 minutes @ 150 degrees, just like the old kids Shrinkie Dinks.
Cover with washcloth, then iron on medium setting....
Decided to try this one, seems to be working. Thanks. Ill keep the oven trick in mind if I need to try it again sometime.
Another question... Even though my machine is on free play, the match feature is on and I'd like to leave it that way (dont ask me why). What I would like to chage about it though is the knocker goes off and startles me when the score matches. Any way to change this? Dip settings are only allowing me to turn the feature on or off. Seems like the knocker is only used for this feature, can it just be removed?
I use a heat gun. The plastic usually bends a little more right before it falls flat. Let it cool while still flat and you are good to go.
