I'll give you the pixel argument if that is what you meant. 160x192 resolution will be OBVIOUS, even on a smaller display, if the signal path is good enough. But if you're talking about the quality of the display, i.e. the sharpness, clarity, purity, etc....then you're wrong. Here's a couple of screenshots from a while back. These were taken using my Viewsonic P815 (21" CRT). Can you tell which one is emulation and which is a real 2600? I couldn't and I was sitting right in front of the monitor. Same monitor, same cable, same lousy handheld point-n-shoot-camera. The image looked identical on my Viewsonic 29GA (29" CRT) and on the 42" LCD at work and projected onto a 10x4 foot whiteboard from about 10 feet away using a cheap LCD projector (equivalent of 80" diagonal). When I took the photos I literally unplugged the VGA cable from my computer and plugged it into the Atari. I seriously couldn't tell the difference. However, those ARE some pretty big pixels...especially on a 80" display....
