No specifics, but the general idea is this:
If not protected, then use a programmer. They can usually read them out.
If protected, study the type of device. Assuming that the device has no internal state (registers), then basically apply every possible combination of input states, and read out the corresponding output states. (A test fixture will be needed to do this)
This will give you a truth table for the device that can either be reduced to a set of logic equations, or just fed back into the device's logic compiler.
This can be done in a completely automatic manner, unless you really want the equtions reduced as far as possible.
Now, if the device has internal state, I don't think there's a completely automatic way to do this. I'd probably start by looking at the scematic of the original use to try to identify things like clocks and write/read lines, then try to use logic analysis to guess at what inputs seem to feed state and which seem to be strictly combinatorial. After that you need some idea of what the thing is for in order to really work out the state and how it functions.
If it's for an older arcade board, I'd also have a look at the relevant mame sources - those guys have worked out a LOT about what the boards DO, which may well inform the repliction of the device.
