I have a nintendo dual system with cyber ball 2072 in it I want to convert the one side and leave the other side cyber ball 2072. Does any one know the correct procedure to convert the cabinet to jamma?
I have to look at the board again but the hardness plug in on the top of the board there like four or five plugs on it ill have to take a pic
http://m.flickr.com/photos/driph/2806885778/ here pic of the board I found online
only going to have a 2 player Cyberball plus a Jamma cab yes that what I want to do one side cyberball other side jamma so ill have get a jamma hardness and probably a power supply for the jamma side ?That is interesting, the Cyberball board I had came from a Nintendo dual upright and was Jamma.
Anyway, it doesn't change what I told you. Buy a Jamma harness and install it on the secondary side of the cabinet. Do you intend to keep the Cyberball fully playable via a switch or some other method, or are you only going to have a 2 player Cyberball plus a Jamma cab?
What kinds of Jamma games are you planning to run? A normal 15 amp switcher can usually handle two game boards. If you are wanting to play some of the newer boards that draw a lot of power then a second switcher is the safe way to go.
just like fighter games action games etc
If the fighters include later Street Fighter series games (CPSII or III) then I'd suggest you get the second switcher.[/QUOTE
thanks for the info the Monitor i can use the same one right ?
