How to connect Sega Model 2 boards
adams_arcade
Donor 2012, 2023
I have a Sega dedicated Model 2A cab. I would like to connect my new board Sega Model 2b.
There is some difference with the connections...
Has anyone done this?
Is there an adapter available?
Would like a solution that does not destroy the existing wiring.
Look forward to your replies
Been a while since I've done this, but the connectors are the same. As long as you are dealing with caged boardsets or at least have filter boards, this will work as-is. The connections are just located in different places on the filter board. You can hook the board up with no adapter.
I see that thanks!
My only question left
The Cabinet has two +5 Input connectors
Using model 2 A Filter CN3 is a +5 input with (4 yellow and 5 white wires)
Using model 2 A Filter CN12 is a +5 input with (5 yellow and 4 white wires)
The model 2B filter board has the +5 inputs on connectors CN 9 and CN 10
So I ask....CN9 Does it get 5 yellow or 4 yellow... the other left over connection obviously goes to CN 10 :)
GOT IT!
Model 2
Ver A Ver B
7 3
13 5
12 9
3 10
10 13
