How to change Wico 8-Way to 4-way? 🤔
Bishop
North Carolina
Does anyone know if there is a wico 8-way restrictor plate to make it a 4-way?
The restrictor plate is built into the housing. And you would need a 4 way actuator as well.
I've converted 4way to 8 way but not the other way around. 4 way had a square (diamond) shape hole cut in it and had a smaller actuator on the shaft. You could probably take a small piece of sheet metal and make your round hole square.
You can't. The bases are different.
4-way bases have diamond shaped holes in both the top and bottom halves of the base, and they use a thinner actuator.
8-way based have round holes in both the top and bottom halves of the base, and use a thicker actuator.
If you need a 4-way, I have refurbed ones available:
