how to adjust Jamma 4 in 1 settings
frogger
Ashland, Oregon
I have a 4 in 1 jamma pcb ms pac, frogger, DK, space invaders its in cocktail set up is there a way to reset the format of the game to upright.
Should b bsome dip switches on the PCB. Adjust those and see what happens. Or try the menu. In the 60n1 board it's either dip switch #1 or 4 that gets you into the menu.
If it has a 4 position dip switch, you have to power up with #4 ON. That brings up the options menu, it's a little goofy to navigate but should do the trick. Be sure to save before powering down and turning #4 back off.
I can get to the menu using the test switch but no settings for the format to upright
Pics of menus
@frogger the last page is where I would expect to see the upright option. I believe that is a very early version of the multi boards. Hopefully someone will chime in that has experience with the early versions.
Try this from the 60n1 manual
After a hour of testing different settings got it to flip around all 4 games free play this is what it looked like
