how to adjust and tighten a spot lamp?
zutton1
Donor 2011, 2018
New York
Ok so I keep on trying to tighten the spot lamp on venom in my spider-man pin...the thing keeps on moving on me...I am trying to tighten the screw, but the lamp is still loose...also tried to tighten the base it sits on still no luck...yes I am new to pins...please help! Thanks!
Easy enough, take the bulb socket off, tighten the post, most likely the post is loose. It is possible the post is stripped, but doubt it. Mine was the exact same. Poor installation.
