How to access displays on Mr. & Mrs. Pac-Man?
Are you referring to the 5 displays behind the black back glass? You should just be able to slide that glass up, then pull it out. Then you basically do the same for the board that the five displays are on. Slide up, and pull the bottom towards you.
Take the backglass off, and put it in a safe place...
Reach down in the neck area; I believe you have two sliding metal pieces that slide over the top of the plexiglass piece that covers the score displays; you'll need to pull these back (towards the back of the game).
Once those are pulled back, you can then lift up the plexi that covers the scoring displays. I had a Centaur II for a while, so had to do this a few times.
Bingo. Thanks.
