All of the Namco blowback guns are the same and I have some Happ 45's on a Pointblank conversion. I would expect standard Happ 45's to work on this machine as well. I just want to swap them out cause
I dont recall if VN uses iR or std light guns. If it uses std light guns then Happ 45's will work and will probably work better then the factory guns. If VN uses the iR guns (which for some reason I'm thinking it does) then you will be stuck with them.
