how much do 19" & 25" monitors weigh?
joemagiera
Thread Manager
I'm at work, otherwise I would just weigh them myself. But can anyone throw a few different monitors on a scale and report back what they weigh? I'm guessing they are all within a couple pounds of each other for the 19"s.
G07, 49xx, 46xx, 6101, G08, 7xxx, Disco, G05
How about a WG 25" 7xxx?
Thanks!
Discos weigh a lot more, I can tell you that. It is the only 19" one that feels "heavy" when I pick it up.
G-07 42 lbs.
46xx 46 lbs.
Those are the only models I have sitting out uninstalled in my work area at the moment.
G-07 42 lbs.
46xx 46 lbs.
Thanks much for the info (and thanks in advance to anyone else that happens to reply with info on another model).
I'm surprised that there is even a 4 lb difference between the two.
Daughterboards, larger flyback on the K4600 with long wires dangling from chassis to it; all adds up.
Perhaps too the G07 he weighed didn't have the metal shield around the outside of the tube and the K4600 did which would add up more.
