Outstanding.
That is impressive.
Your solution to the screen rotation dilemma is slick (and one I would like to steal!)
Yep, I can rotate my Vision Pro like a pro! There is a eyelet screw in the bottom back, unscrew, rotate, rescrew, done. 270 degrees. I had to put the large vent in the back to let the neck board clear the back of the cab.
Oh, and the black monitor surround bezel is mounted to the monitor, so when you rotate the monitor, the bezel goes with it.
And when you want to connect any jamma board, you can set it on the top tray on the top back of the cab. The tray holds most pcb's and slides down on to the angled wood handle on the top of the cab. Just connect the JammaOutTheBack extension and you are good to go.
To credit the machine, push the red coin reject button (like my avatar) and that pushes a leaf switch together which coins up the game.
Inside the coin door is a lighted custom service panel that has the power switch for the NAOMI power supply, the volume control, the on/off switch for the marquee light, the +5 volt switch to send +5 to either the spinner OR the trackball on the Arkanoid panel, the on/off switch for a fan at the bottom of the cab, a service button and a test button.
I have the top marquee bracket held on with velcro, so I can change the marquee in under 5 seconds. It works great.
Only two wingnuts are used to secure each control panel to the cab, so changing them is super quick as well.
