Looking to fix up a DKJr cabinet with laminate. Has quite a few bondo areas that I need to cover.
I understand the cabinet sides with small router from videos I've seen, but how do you handle the front that has inside edges? Do you take apart the cabinet and route the edge of the front, or cut the laminate to fit? Do you just use a straight edge and razor blade, then hope it goes on straight with the contact cement for the front?
