OK, so what does this part of the title mean then?
DIP 16 Pin IC Clamp IC Test Clip
Before I bought it I asked them if it was a DIP test clip and they said:
we have tested this model on Programmer Testing Clip SOP SOIC 16 SOIC16 DIP 16 Pin IC Clamp IC Test Clip, if your device model is line in with out title list, it should be work well.
Thank you and have a good day.
There are many Chinese Auctions on Ebay with this title.
I believe it to be a mis-understanding.
You need something like this -> (note the "larger look" and relative pin spacing)
https://www.greatplainselectronics.com/products.asp?cat=6
Where smaller DIPs are 0.3" pin spacing (side to side) defining the clip width:
But hey, if you want to believe the Chinese over this Canadian, that's OK with me.
