m_mcgovern
How I made a Williams 4114 to 4164 RAM adapter
So, I finally got around to making two 4114 to 4164 RAM adapters for my Sinistar and Robotron. I thought I would just add my 2 cents to one of the great tutorials that are already linked to in this post from YellowDog:
http://forums.arcade-museum.com/showthread.php?t=81015&highlight=4164
1. First, get a 9-pin header (I got mine from Bob Roberts) and clip off pins 4 and 5 (counting from the left). Save those clipped pins.
2. Next, solder one clipped pin across pins 1-3 (GND)
3. Then, solder the next clipped pin across pins 5-7 (your new 5V).
4. Then, solder on trifurcon pins (I got mine from Bob Robers) onto pins 1-3, 5-7, and 8 one-by-one. I found it easiest to get them in position by "crimping" them with a pair of needle nose pliers first. Then, I dabbed on some flux and soldered them on, trying to keep them as aligned as possible.
5. Next, slide on the 9-pin housing (from Bob Roberts, of course) and voila, a 4114 to 4164 Williams RAM adapter in less than 30 minutes.
Here are some pics:
This pic shows which pins are clipped:
This pic has a better view of the clipped pins soldered across pins 1-3 and 5-7
The nice, compact finished adapter:
Let me know if you have any questions...
Here are some pics:
