How Exact Doe My Monitor Mount Need to Be?
nerdygrrl
Portland, Maine
Ok, I am converting a particle board Popeye cabinet to a DK and I need to drill and install a vertical mounting bracket. I thought I could use one of my plywood cabinets as a template. Line the two cabinets up side by side, clamp them and then drill through the holes the plywood cab through the particle board cab. Unfortunately there appears to be a 1/4 inch height difference between the two cabinets. Does anyone know how much wiggle room there is on this? Is 1/4 inch something I can get away with?
Doe?? What does this have to do with arcade monitors? :D
